Powder Coating AC Accumulator
  • Powder Coating AC Accumulator
    Will powder coating hold up on an AC accumulator with the temperature changes it sees? Would powder coating mess with the efficiency of the system?
    If you want to find out let me know! Could probably help ya out.
    Sent from my iPhone 5 using Tapatalk
      Once powder coat melts it bonds to the surface if done right.I don't see any problems with getting it pc
        PC will be safe
        Actually, you only need to be careful when burning OFF powder coat with aluminum.
          What will the heat do to the desiccant ?
            My exact question
            2015 Silverado
