i have a 1995 trans am with ram air and lt1... does anyone have any pics or walk throughs of relocateing the passenger side wheel well wire harness or the fuel lines or other cool ideas and pics... thanks
lt1 engine bay
Regular
- December 29th, 2010
- 186
- Jamie Schnowske
- 1995 Pontiac Trans Am Ram Air WS6
- Peoria .IL
- Menards stock - Dad
Go to ls1tech... use search... i'm sure i've seen it thereOriginally posted by s-10fan262 View Posti have a 1995 trans am with ram air and lt1... does anyone have any pics or walk throughs of relocateing the passenger side wheel well wire harness or the fuel lines or other cool ideas and pics... thanks
Lots of good info on LS1 tech. I relocated the passenger side harness, and the hood latch cable. Haven't looked into the fuel line relocate.sigpicJust a slow 400 plus RWHP LT1.....428/370 NA
I did the fuel line relocation and passenger side wire mod. I still need to do the hood latch cable. Basically you drill a hole through the strut tower for the wires or fuel line and then reroute them through the hole. For the passenger side wire mod, you drill the hole and then route the wires through the hole, between the strut tower and the plastic wheel well cover, then by the battery there's an opening that you can route the wires back out through. For the fuel line relocation, once the hole is drilled you route the fuel lines out through the hole (it will come out by the master cylinder) then you just route the fuel lines behind the master cylinder and back into the fuel rails.- Brian Meissen
Regular
- 186
- Jamie Schnowske
- Peoria .IL
This is the exact same process as the LT1.Originally posted by BP_Z28 View Posthttp://www.flickr.com/photos/lswon/2...7603647740314/
Done on an LS but should be about the same I assume- Brian Meissen
