Originally posted by mcalus
View Post
Un less you use a base coat activater and it shortens that window and each coat needs to be smooth or your final finish will suck if its gritty not good do not clear it sand it down then reapply base coat till its smooth as you can get it. A little peel fine and a few little nubs. Will polish out of clear but from what your saying that is not ok to clear it check your over lap make it 50% and keep your distance at 6/8 inches do a mediam to wet coat let flash and clear it same way then you can wet sand and polish
.. and make sure you use the rite reducer check your mixture see if it is then enuff. Read the derections for mix even if it says ready to spray it can be to thick if I'm rite this is a lacuar paint if it is you should be able to use lacuar thinner to thin it if nit is not lacuar than you can not you use lacuar thinner.
