And so it begins.....
  • #76
    Got the car all the way up in the air today(so my fat ass could fit under it).. Worked from 4:30 am to 11 today, so not very motivated.. Did a little bit of cleaning is all.. Just a rough cleaning, found a few loose nuts that I need to snug up.. Only did from the tranny mount back to the rear end.. Then lost motivation.... Time for nap..
    • #77
      Nice and clean! I can't wait to do the same thing!
      What are you using to clean, simple green?
      • #78
        Took some industrial degreaser and mixed with water.. 50/50, worked very well.. My cutouts had put a lot of soot on the underside of my car.. and just general filth from being neglected the last couple years...
        • #79
          Naps are awesome...plan on taking one myself this afternoon. Never under estimate the power of a nap. Looks good Larry.
          • #80
            Naps are awesome..
            Yes they are.. Nap time begins now!!!
            • #81
              Lookin' pretty spiffy there Larry!
              • #82
                Little progress today.. Have my hot wire ran, now to secure it, cut it off near the battery for my 200 amp fuse, assemble.. Then on to the rest of the wiring disaster for my nitrous kit...
                • #83
                  Looking really good Larry.
                  If you sell your Trans Am,
                  • #84
                    LOL, I am actually leaning towards skipping the vette idea indefinitely.. I don't want to be banned...
                    • #85
                      nice progress, the underside of your car is very clean im jealous. i like all the suspension mods too. bmr ftw
                      • #86
                        Thanks! The only thing BMR under there is the LCA's.. Sway bar and TA are Spohn..
                        • #87
                          looks good larry. id wire tie that positive cable in as many spots as possible and where it cuts through the paneling id stick a rubber hose or wire loom around them spots that might rub through. my car could never look this good. that thing is damn clean!
                          • #88
                            I will have cable fasteners about every 6 inches and I have some good stuff from work to cover that square opening to prevent rub.. I won't take any chances with that cable rubbing on something and shorting out.. Also going to put cable covering over the whole thing too..
                            • #89
                              Suggestion...
                              I did a battery relocate similar to what you're doing. I also used a fuse at the battery. Um, long story short? I kept blowing the fuse. I was using a 150 amp fuse. I kept popping them light party balloons. This happened back before I realized the stock starter just wasn't up snuff (heat soak). Might I suggest using a circuit breaker instead of a fuse. If the breaker ever trips, its a helluva lot easy resetting a breaker then it is having to buy another fuse. Not to mention, if you found yourself stranded out in the middle of Bum F uck Egypt.
                              Jus sayin.
                              Clamaped up tighter than a 15 year old on her first prom date...
                              • #90
                                Originally posted by squareandcompass View Post
                                Suggestion...
                                Jus sayin.
                                Circuit breaker purchased...
