6LiterEater Gauge Overlay Installed!
  • 6LiterEater Gauge Overlay Installed!
    I still have to do the MPH needle which I'm completely stumped as to how to reinstall accurately considering it just "rests" on the clear bezel piece until I start moving. Without the bezel in place, I don't know where to line the needle up. Still gotta figure that out.
    But - here's some progress pictures!!
    cool B looking great man!
      Nice! very cool touch..
      I have no idea about the needle..never pulled em off before...
      < Black Betty >
      '94 Formula, 385ci, T56, Forged ESP internals and LOTS of bolt ons www.cardomain.com/ride/3000929
        Pretty sweet B!!!!!!!!!
          hey B, how hard was this to do? do you need to pull the dash out to get at the gauges, i really want to do this, except get white face gauges and replace the bulbs with green leds for now
            Brian could it be that it spun like further down? I know there is like only one way to put these on or I think that;s how it was on my camaro with the mph at least, but if it was spun to far that would then prevent you to put on the needle, sounds simple i know and i could be completely wrong but just thought i would try ha, they look great either way!
            1978 Chevy Malibu Classic:
            350 Crate Swap, Turbo 350 Transmission, Flowtech Full length Headers, Flowmaster 40's Mufflers, Tru-Dual Exhaust, Goodmark 2in Cowl Hood, Northern Autoparts Racing Aluminum Radiator, Jasper Pearl Paint Job, Billet Specialities Vintec Wheels
            1994 Chevy Camaro: Sold
            Former Projectcamaro Member
              That looks great Brian! So you finally got a V8 gauge cluster huh?
                I'm not too sure, Vince. I think at this point the only way to really know would be to data log while I drive and see if the mph matches the needle.
                And yeah, Fred, I've had a v8 cluster since the rebuild from the spun bearings.
                  Make sure whatever you get replaces the gauge face and doesn't just stick over stock. I've done it both ways and what you stick over stock will not show the green LEDs correctly because there's a blue film behind the stock gauge face.
                  It's not really too hard to do... though a little time consuming. For my 97+ dash, I just had to drop the knee bolster, pop the gauge surround bezel out, and then unscrew the 4 bolts to the gauge cluster. But then the hard/time consuming part - I have to lower my steering column to get enough room to get the gauge cluster out. It's two 13mm nuts that are in a position just perfectly to make it impossible to use a socket on.
                    Looks sweet!
                      yikes, you have to remove your needles to install those? Not sure on the 6 Liter ones, My white gauges were a very durable vinyl/plastic that did not stretch at all, the holes were just big enough to get around the needle base on one half and the get it over the over half, cant see behind the needles anyway. Gives them an orange glow around the needle base as well. Had mine installed in like 2 minutes after getting the bezel out.
                      -Derek-
                        does 6litereaters replace the whole gauge face or no? lol go figure u cant get a socket where it needs to be on a camaro
                          looks awesome! i wouldnt have done the shadows though.
                            That looks good, Brian.
                              That's cool as hell!
