Well, during the process of taking the motor out of my car, it's aquired many, I don't want to call them scratches, but like blemishes in the paint. Should wheeling it out take care of these?
Wheeling a car
Obsessed
- October 31st, 2006
- 986
- Dale
- 2002 Camaro v6
- Millington, MI
- retail, and body work on the side
depends on how bad they are but as long as they are just in the clear coat you should be able to wheel them out, just make sure you get a good compound like "clear cut" by 3m stuff works great for making the finish of your car smooth, use it with a wool pad and you should get great results. Then finish it off with a light cut or even a couple passes with a machine glaze to let the color shine through. You can get all that stuff i said at painters supply. Sorry if you know most of this, i just assumed i would throw out everything i would do. I plan on doing this to my car in about a week in order to get that shine back.sigpic
"Blue Devil"
Even light scratches can we taken out.
even if you have to wet sand some spots down.
I told you I'd hook you up Ricky. I'll make that thing glow!
People think Claybar works wonders....LOL, that's because they don't know how to work a wheel!
It's that people don't know to take the steps and they think a simple orbitial works. Claying does work wonder's but not as much as a wheel will. Speaking of that, I need to wheel my Camaro.Originally posted by tenpin842 View PostEven light scratches can we taken out.
Joe - ATM SQUADAt the shop, watching them build my car.
Obsessed
- 986
- Dale
- 2002 Camaro v6
- Millington, MI
1200 grit + Wheel + Wax=
"Blue Devil"
its important you use a foam pad for the light cut stage!Originally posted by cobalt camaro View Postdepends on how bad they are but as long as they are just in the clear coat you should be able to wheel them out, just make sure you get a good compound like "clear cut" by 3m stuff works great for making the finish of your car smooth, use it with a wool pad and you should get great results. Then finish it off with a light cut or even a couple passes with a machine glaze to let the color shine through. You can get all that stuff i said at painters supply. Sorry if you know most of this, i just assumed i would throw out everything i would do. I plan on doing this to my car in about a week in order to get that shine back.
If you really want shine, finish it off with a waffle pad and Seal-B
Color comes out like you wouldnt believe.
a wheeling finished off with that and a couple layers of wax is downright jawdropping.-Joel
time for some showing off
