Im having a problem with my pass side window sweep popping up at the back I was wondering if anyone has also had a problem with this?
Window sweeps
Window sweeps
01 NBM Base SS build #514 M6 Pat G/EPS 230/234 111+4 Cam, LS2 Heads, Tick Master,Extreme Chassis 8.8 with 4.30's, BMR LCA And Torque Arm, Edelbrock PHB, FIPK intake, Ported TB. Jet-Hot LT Headers TSP True Duals Tuned By SB Tuning
Tags: None
mine does this as well, I would think the best fix would be to buy new trim pieces to replace them. Let me know what you do if anything.Doing less with more
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
those are available at the dealer, we replaced them couple years ago on B's car. Pain in the a@@ to do but worth the effortsigpic
mine has this problem too. looks like replacement is the only option...
ya I pulled the door panel off to try and get at it and there really not much clearence unless you take the door apart so its going to be a pain Ill keep ya posted im doing them this week01 NBM Base SS build #514 M6 Pat G/EPS 230/234 111+4 Cam, LS2 Heads, Tick Master,Extreme Chassis 8.8 with 4.30's, BMR LCA And Torque Arm, Edelbrock PHB, FIPK intake, Ported TB. Jet-Hot LT Headers TSP True Duals Tuned By SB Tuning
