I've only ever seen the grills with the 4 holes in the center around the Camaro. I've never seen them where the stock holes are. What brand is it? Any close up pics?
Installing a billet grille
Brian yu are 100% correct and that is what is being seen in that picture. GMMG just blacked out that area so you would not see body color paint being the grill.Originally posted by meissen View PostIt's hard to tell from that picture. I think, and hopefully someone with a 98+ can correct me, if you pull the stock black insert off that the bare grill behind it still says "Camaro" as it does in that picture.
And FYI the Tom Henery cars were built by GMMG.
Thanks guys for the info. I took some of your advice and I got it off with out hurting the stock grill. I pulled the sides out, then lifted the bottom of the grill to were I could see the clips. Then took a narrow screwdriver and inserted it into the metal clips on the bottom and twisted them. The tabs came right out. As for the top. I just pulled hard with steady pressure one at a time and the pins pulled right out.
