uneven headlights
  • uneven headlights
    For some reason, when my lights are down they don't match up with the hood at all. One cornner sticks way above the hood while the other is way below. Both my lights are like this. It's like they're in crooked but I don't know how that's possable. Anyone dealt with this?
    I know my hoods fine because it matches up well with the front bumper and fenders well.
    I'm much more active on TGO as they have more info pertaining to my model, but I do stop by from time to time.
    Adjust em against a closed garage door
      i think he means that when the headlights are down (they are hidden head lights) that the panels (body panels) dont flush out with the hood and fenders... right?
      anyways i dont know really but im guessin there has to be an adjustment somewhere. bump for ya.
        There is a way to adjust them, but it's rather tedious. Look at the sides of the cover when the headlights are up. You'll see 4 philips screws. Take these out, and carefully remove the top (body color) part of the headlight cover.
        What's left beneath this is going to be black, and there will be 4 torx screws on the top flat surface, one at each corner. The cover is adjusted up at each corner by loosening these torx screws, and down by tightening them. Be careful not to over tighten, as it's easy to strip out the plastic part that it's screwed into. It's rather time consuming because you have to keep installing and removing the top cover, but the results make the work worthwhile. If you need more help, PM me.
        Nick H.
        Current MIFC Vice President
          This is why I love the headlights I have on my camaro.
            Thanks for he help. I can't stand how the lights look now. I'll go and try that, let ya know if I have any problems.
              Great question as I've got the same problem with my passenger side light, the rear of the light is lower than the front and it makes the lines look like crap. I'm going to try the same thing.
              LIFE IS SHORT! LIVE IT TO THE FULLEST! ENJOY YOUR PASSION, YOUR FAMILY & FRIENDS!
              STS Turbo 5-6 lbs boost, Rebuilt Jasper engine, Hypertech 160 stat, Pillar Gauges, 52mm Throttle Body, Air Foil, 42# Fuel njectors, LT1 Aluminuim Elbow, Synapse Synchronic Blow Off Valve, New Stock Fuel Pump, Holley Fuel Pressure Regulator, Lakewood Traction Bars, Auburn Posi Differential, Welded Frame Connectors, Z06 Replica Wheels 18" x 9.5" with BFG G-Force Rubber 245/40ZR-18 275/35ZR-18, Honey Comb Tail Lights
                :X2:
                Good luck with the fix, guys!
                  Great question, Kerry, and great answer, Nick!
