Sound deadener.
  • Sound deadener.
    I heard about this and want to see what everyone has to say... I read this over in a ford truck forum but figure it may be useful for all cars...
    Anyone care to chime in and give opinions on it?
    Also available at the building supply store is aluminum covered bubble wrap insulation. It's cheaper than dynamat and works well under the carpet or inside the doors and headliner. Just use strong glue to attach and hear the difference.
    1989 Chevrolet Camaro- Currently in pieces...
    umm air is a good heat insulator, not a good sound insulator
      Ditto...you want rubber, not air pockets.
        ah ok.. i read it on ford-trucks.com when i was reading threw there "tips and tricks" section for 73-79 pick ups. and thought that if it worked would be a hell of a lot cheaper then dynamatt or anything like that.
          My dad used that in his street rods for heat insulation. It doesn't do much for sound insulation though.
          Wade
            you can pick up some like rubber roof sealing stuff at home depot or lowes... i pt that in the back well of my camaro and it cut out the rattling from my system
              my dad has in supply this type of insulation that looks exactly like dynomat, but is much cheaper cant member what is.
              Mods:
              Ram Air Intake (CAI)
              K&N Filter
              Polished Throttle Body and MAF Sensor
              De-screened MAF Sensor
              Tightened Throttle Body Cable
              Performance Button Setting Changed for Torque
              160* HypterTech Thermo
              Water Wetter
              New Distributor, Plugs, Wires
              New Water Pump
              LT4 Knock Sensor
              Flowmaster 40 Series Muffler
              TB AirFoil
                meh dynamat is still the way to go
                just sucks when you sometimes prick your finger from cutting
                  i install trunk kits from dynamat all the time, my 100% choice, but i know of products cheaper that will work almost as good as dynamat.
                  99 Grand Prix GT - Winter Ride
                  ___M&R Electronics ___
                  .MECP & ASE Certified.
                    I've used "brown bread" or B-quiet and they both worked as good if not better than dynamatt, for half of the price, look on ebay, i remember buying 100 sq.ft. of b-quiet for 125 bucks, that's like the equivalent of 1200 dollars of dynamatt. I used it in my cavalier, and it worked great.
                    "Blue Devil"
                      never heard of that?
