I don't know I can see where the hole is in the block just a little ways up above the oil filter. I am assuming it has been plugged up because there is no oil coming out of the hole. I got a list of other problems with this car too from the original owners crack job of an engine swap. I have to find a new place to power up my shaved door handle button because right now the purple/Blue power wire is litteraly sticking into the fuse panel into one of the fuses As you can see in the picture. The button is on the left rear wheel well. the power wire runs from the fuse panel under the carpet and through a hole in the body to the wheel well. My gas guage and temp guage don't work at all. My speedo kind of floats a little while driving and my car runs rich. And I can't seem to find the knock sensor. Then agian it is a 74 350 CMj engine and I am sure whoever did the swap did not put the knock sensor in. You can also see I have a bit of a rust problem on the left front strut tower. Its rusting around the strut mount. How do I fix that?
Oh and if anybody wants to stop by my house feel free. I work 8-5:30 weekdays and I and free saturday and free Sunday after 2:00pm
