Congrats Kolin!! Everytime I see your Camaro I
. Very well done!!DRYSUMP
Here's what Kolin has to say about his Camaro:
The car started out like any other car project. I just wanted to do a few tasteful mods and clean it up a bit. Then it completely snow balled into what you see now. It is the second 4th gen f-body to get the full Katech Track Attack treatment. I built the car over 7 months in 2012/13 and drive not only on the track but on the street as well. Now onto the mods...
Current list of mods:
Engine:
Katech Track Attack LS7 - 650hp 575tq
LS7 aluminum block with billet main caps and 4.135" bore
ARP Main studs
ARP Head studs
ATI Damper
Callies compstar crank 4.000" stroke
Compstar 6.125" connecting rods
Mahle pistons CR 12:1
Katech piston squirters
GM Stage 3 camshaft 233 276 .630 .630 107 lsa
GM high speed lifters
Katech C5R timing chain
Katech LS9 high capacity scavenge and pressure oil pump
LS7 CNC ported heads
LS7 titanium intake valves and sodium filled hollow stem exhaust valves
PSI valve springs
Katech upgraded LS7 rockers
Katech ultra-lite titanium retainers
Katech carbon fiber valve covers
FAST 102 Intake manifold
FAST 65lb Injectors
Katech Billet fuel rails
Katech Billet fuel rail crossover line
Katech coil relocation kit
MSD wires
Katech Billet tensioner
Katech auxiliary oil cooler adapter
Custom built dry sump oil tank
Suspension:
Strange coilovers with hypercoil springs
BMR Upper A-arms
BMR Lower A-arms
BMR Tubular K-member
BMR front sway bar
BMR rear sway bar
BMR torque arm
Poly engine mounts
Poly trans mount
Founders adjustable panhard bar
Founders adjustable rear lower control arms
Founders lca relocation brackets
Founders Sub-frame connectors
Other misc mods:
Aeromotive stealth 340 fuel pump
Custom battery relocation
Hurst short throw
Katech LS9X Clutch kit
Tick Performance adjustable master cylinder
AP600 racing brake fluid
Hawk HP+ brake pads
Hawk Quiet slot rotors
Toyo Proxy R888 tires
Custom brake coolers
AEM Fuel pressure gauge
AEM Oil pressure gauge
AEM wideband gauge
Custom modified Halltech Air intake
Dewitts Radiator with integrated oil cooler
