Camaro has created a tick :(
take the belts off and start the car
if the noise goes away add the a/c belt and try again - if it comes back it's one of the idlers, if not put the main belt on and see
I just repacked mine and they are still making noise
2000 Formula
fixed slow junk
Ya I second removing the belts and checking the idler pulley / ac pulleysigpic
2004 Cummins 3500 4x4 QCSB Auto, 5" Exh, CAI, 20" GunMetal7s, 35" Goodyears, Fender Flares
03 Z71 Loaded, Bose, Htd leather, etc (Sold)
00 Camaro Z28 M6 T-tops (Sold)
00 Camaro SS A4 T-tops (Sold)
99 C5 Corvette M6 (Sold)
98 Camaro Z28 A4 Coupe (Sold)
98 Camaro Z28 A4 T-tops (Sold)
96 Cummins 4x4 36lbs boost (Sold)
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
sounds like a bearing on one of the accesory brackets.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
85 Z28 406/th400?/3.42 4th gen disc rear/4th gen dash
00 Tahoe Z71........Stock
97 K1500 lt4 cam, 1.6s, MPFI, Solid axled, IROKs,------winter beater
As the months get warmer, going to be re-address this problem since I did not do anything about it.
Plan on taking belts off and spinning each pulley. Then I will work my way to the rockers.
Sent from my C811 4G using Tapatalk
