1987 IROC Camaro 5.3/4L60E swap
  • 1987 IROC Camaro 5.3/4L60E swap
    I have the chance to build my dream car so I am sell my 1987 iroc camaro with a ls swap. I have owned this car since 2001. It's a t-top car. Body has 144,000 miles on it. It originally came with a 5.7 tpi. This past winter I installed a 5.3/4l60e combo.
    $10,000
    2003 5.3
    stock bottom end
    LS1 intake
    LS1 injectors
    Fast fuel rails
    Fast fuel pressure regulator
    -6 an fittings and braided lines
    Tranny
    Stock 4l60e
    TBSS converter
    Suspension/Brakes
    Founders Lower control arms
    Founders panhard bar
    4th gen stock rear end
    UMI torque arm
    LS1 driveshaft
    Hawks transmission crossmember
    Spohn A-arms
    Eibach springs
    Koni adjustable front shocks
    Brembo CTS-V front brakes
    4th gen master cylinder
    Interior
    New carpet
    New headliner
    Redone 2000 camaro seats
    Double din head unit
    Installed sound deadener throughout the interior
    Other
    LS1 fuel tank
    Racetronic pump harness
    Racetronic walbro 255
    Custom LS engine harness
    411 computer
    Knockoff LS headers
    Custom y-pipe
    Mangaflow exhaust
    Battery relocation
    18" black 5 spoke wheels
    Nitto tires with 90% tread left
    The Bad:
    -Speedometer doesn't work. I am running a scan gauge which tells you mph. You can also by the conversation box to use the stock speedometer.
    The original wiper motor was to close to the driverside head. I swapped over to a Nissan Maxima wiper motor. It's installed just need to be hooked up.
    The car doesn't have the heat hooked up. I have all of the parts just never had time to install everything. I never used it so I didn't bother to install it.
    If you have any questions please let me know. Will get some better pics soon.
    Air Force/Afghanistan veteran
    1987 Iroc camaro Supercharged 5.3
    2012 Toyota tacoma
