Do air foils on the throttle body make a difference?
  • jakes_GSXR
    replied
    I'm pretty sure its only 25 bucks on Ebay everyday. I'm willing to spend 25$ on my car and not spend it on myself later.
    Leave a comment:
  • MP81
    replied
    I'm pretty sure it helps with throttle response, though.
    Leave a comment:
  • shawnc16
    replied
    If it "added 5 hp" it probably didnt add any hp.... dyno numbers are always different after each run.
    Save yur money.. buy something that is going to net you legit power gains
    Leave a comment:
  • WMCCjames
    replied
    Originally posted by WMCC SSLS1 View Post
    Back when I used to run TPI stuff I had a noticeable gain on both a 305 and a 350 engine and would recommend it. Of course find the best price you can and even look for a used one as nothing can go wrong with them obviously. $20 to $30 sounds good and remember people spend $150 + on the LS1 cars for a similar gain from an air lid which is just a piece of vacuum formed plastic. The air foil won't give you 50 magical HP but is will help throttle response much like porting the TB on a LS1 engine.
    Somewhere around here I have an OLD copy of a book from TPIS from the 80's where they went step by step and changed pieces like the air foil, air filter, runners, plenum, milled MAF heat sink fins, and they even tried a Corvette air box stock and modified, Camaro and Firebird air filter boxes. Each piece was attached to a flow bench to measure the airflow change in CFM. I don't have the exact numbers in front of me but the air foil did increase the CFM through the throttle body which makes sense as the GM TPI throttle body is about as aerodynamic as the front of a city bus.
    Gotta love that old TPIS info!!!! I have that same book floating around here too...that was my bible back in the day.
    Leave a comment:
  • WMCC SSLS1
    replied
    Leave a comment:
  • Virtue
    replied
    x2 waste!
    Leave a comment:
  • Guest's Avatar
    Guest replied
    waste of time and money
    Leave a comment:
  • b.lee
    replied
    I've always heard they are for suckers?
    and can lower hp.
    Leave a comment:
  • TenaciousB
    replied
    Hp to $ ratio isnt exactly optimal at $50. I'd pick it up for $25 or so.
    Leave a comment:
  • MP81
    replied
    I'm trying to find one for like $20. I really don't want to spend more than that...
    Leave a comment:
  • tenpin842
    replied
    I even bought one for my 305. But I paid $20.00 for mine.
    Leave a comment:
  • DanO
    replied
    i always hate how they say "40 CFM increase"
    increase at what condition, what pressure drop, total flow rate, etc..????
    its a proven fact that things like this arent truly tested, they just "look cool" so people would buy them.
    Leave a comment:
  • transampimp
    replied
    I paid $30 for mine off ebay several years ago. I noticed an increased sucking sound in the intake. If you look at the throttle body you wonder why this was never machined into it right off the bat. I would buy one, just don't spend $50
    Leave a comment:
  • shawnc16
    replied
    honestly for 50 bucks.. It aint worth shit. If you buy an aftermarket TB it will have it already. It doesnt do shit.
    Leave a comment:
  • jakes_GSXR
    replied
    You will probably see a little gain when your pushing 500 hp or more.
    I've got one on my little 350.
    Yeah, I'd buy it.
    Leave a comment:
