1995 Camaro.
I saw when I removed the old bushing shells from the front lower control arms (front bushings) that it was not pressed in all the way. Had poly bushings.
Flanges were not up against control arm.
Is there any way to set these at the proper depth without using the GM special tool?
I am replacing the polys with Moog replacement rubber bushings.
Also does the front lower control arm rear bushing press in with flange against control arm?
I would think so as the weight of the car is pressing down on these.
