Car is gone...traded for a 1937 GMC truck
Thanks for looking!
Dave
<<I'm really not sure if I want to sell this car or not but I do have an oppertunity to pick up a 32 ford truck that I've been wanting for years so I'm going to put this out there to see if anyone is interested....
The car is a 96 Formula 6spd with BONE stock LT1 (never had the valve covers off). It has 69,000 miles and runs like new with cold Air Cond. Here are some details:
1) Rear mounted 74mm turbo (located in the trunk well So it does not hang down like most rear mounts).
2) 60lb injectors.
3) 2 fuel pumps in the tank
4) Crank Case evac system is the A.I.R. pump that comes on with a hobbs switch at 3lbs of boost.
5) Running 2 bar map sensor with the stock computer and working perfectly. I have all the tuning software and data logging stuff...you need the laptop to run it. I can easily teach anyone how to tune this thing, 2 bar tune has been a life saver for these LT1 cars with boost.
6) 4.10 gears in the rear end. (not the best for boost but I can still get about 3 lbs of boost in 1st gear).
7) Large front mount intercooler that keeps the temps in check perfectly.
8) Triple gage pod with Fuel Pres./Wideband/Boost gage.
The interior is near Mint, the exterior looks great but is not perfect...
I have tuned the car for 5lbs on 93 octane and it runs great with plenty of power. I also worked on an E85 tune last fall before they went to the winter blend and went up to 10 lbs of boost, worked great except the clutch will not hold at 10lbs in 4th gear on back to back runs so I just turned it back down and loaded the gas tune back in before it went into storage. I have had no issues with the clutch since but I know it will slip if I turn the boost back up. If I keep the car I will put in a good clutch and turn up the boost and finish tuning for 12 lbs. I don't have any pics of the car after the turbo install but I do have some before. If anyone is REALLY interested I can take some and post or you can just come and check it out yourself. I'm located in Plainwell Mi.
I'd like to get $6700 for it, I know the economy and all is not great......
Thanks for looking!>>
Thanks for looking!
Dave
2) 60lb injectors.
