4:10's, 10 bolt AXLE, Power steering rack, LS1 LT's, MUCH MUCH MORE!!!
  • 4:10's, 10 bolt AXLE, Power steering rack, LS1 LT's, MUCH MUCH MORE!!!
    Looking to get some parts put on the cars before the summer.
    All parts are for a 99 Z28 (M6) or 93 Z28 (A4)
    4:10's for LS1 (don't know if it matters LS1 or LT1)
    10 bolt axle, rear is making a noise, searched on tech and I believe its the axle bearing and if it is most likely the axle is pitted.
    Power steering rack for LS1
    LT's for LT1 and LS1, painted or coated, can't afford S.S. Cheaper the better.
    Water pump for LT1
    Any random gaskets for LT1 (NEW ONLY PLEASE, let me know what you have)
    93-97 Hood, cheaper the better, paint doesn't need to be in good condition as I will be repainting it anyways, don't need latch or hinges.
    Salad shooters (always can use an extra rims, DON'T want to spend much at all on these so please don't give me a HIGH quote, thanks
    19" tires... Need BAD! 255 or higher .... / 35 or 30 / 19... I will take used ones!
    Interior fuse door for 93 Z28.
    Plastic panel that holds headlights in place. (93 Z28)
    I'm sure there is more. Give me some quotes, if you have part let me know but I won't be able to buy right away depending on price. Trying to get the project car and 2 Camaros, a beater and going to college is hard so the lower the price the better
    Thanks everyone!
    2002 Z28 Camaro A4
    I have the same problem with my rear. Took it out and the axle was pitted pretty bad. Good luck
      Ryan (threehonks) might have some salad shooters. He just bought a camaro and hates them so I think he was trying to replace them. Good luck.
        i have 2 10 bolts out of a 93 firebird and a 95 firebird...they are still under the cars accualy. lol not sure if its what ur looking for or now.. they are non posi.. drum brakes.. buy good rear ends.. 150.00 ur choice.. also look at my threads i have some rims on the 95 white and 93 green that im parting out.. the green one with the ultras are flaked abit but would be great for someone wanting to powder coat them.. 125.00 for those.. and the ones on the white are bbs aluminium not in that bad shape either.. 200.00 for those with the tires as well ii beleive they are both 16"
          I dont need a whole new rear. As for the rims the last set i got 2 salad shooters with tires for 25 bucks. Thanks tho
          2002 Z28 Camaro A4
            still need a power steering rack ?? i have a whole cradle i just pulled out still has the motor and trans connected.. its a v6 but i beleive the rack and power steering would still be the same
              I believe the gear ratio is different than a V6. Thanks tho.
              2002 Z28 Camaro A4
