I pulled my stock intake this weekend to prep for an upcoming LS6 intake swap...and, busted the oil pressure sending unit. Overall, the removal was fairly easy. My hands and arms look like I duked it out with a feral cat for a while, but all went well.
So, it got me thinking...I had a few questions I was hoping experienced folks could weigh in on:
1) Has anyone had an issue in running a "de-ribbed" LS6 intake with the LS1 coolant crossover? Seems a lot of folks to this, but of course on Tech there's always a couple who claim they had interference causing vacuum leaks.
2) I assume it'd be best practice to swap the intake runner gaskets/seals. I've heard some (FAST?) may be thicker than others, which would be a good idea to give a couple thou more clearance for the LS1 coolant crossover. Experiences/thoughts?
3) OPSU...are they all created equal? Should I go Delco, or just get whatever is cheapest? Given the PITA location of the oil pressure sending unit, I'd just like to do it once.
4) Knock sensors & harness...should I just get a new harness? I saw a few indentations in the sheathing of the stocker, I presume from when it was assembled at the factory. If I do replace the harness, again, should I go Delco at $40, or Dorman at $20? What about sensors? Replacing the knock sensors and harness is $100-$125 I'd prefer not to spend, but will if it makes good sense to while I am in there.
5) Anything else I should be doing while my intake is off, either to the exposed areas of the engine or the LS6 intake before it goes on?
Here are some pics because why not...
