The wonder bar is an add. Pontiac did not use them.
Touched up some rusty spots on the air cleaner lid. Not pleased with the result, but at least it will stop the rust. Not repulsive, but not pretty either. I have another air cleaner that is the long-term solution.
Shocks and struts painted. Didn't come out great either, but as I mentioned, was doing it more for rust protection than for looks. You can't see much of them when installed, some I'm OK with it.
New K&N cleaned, dried and re-oiled.
Got the old front sway bar end links out tonight. Had been soaking them in Blaster, and trying to drive the bolt out but both seemed pretty well rusted to the outer collar. Tonight I took a sawzall to the passenger side, and before I could get all the way through the only metal cutting blade I had was done. I thought, what have I got to lose by trying once again to drive it out with a hammer. And lucky day, out she came. The driver side came out with no cutting at all. So I'm ready for the new ones when I get the struts on. Just leaving them out of the way for now.
Those are another story. I'm still screwing around with the damn strut bearings. (Shown here with the bearing sitting on top....I know it bolt in from below). I slipped them into position on the struts today, and they are quite loose fitting. Does not seem right. It would be counting entirely on the clamping load of the top nut on the strut shaft to hold it together and not rattle, and to not let the shaft shift around in the too-large opening. The bearing is also not quite straight, and I can't get it to straighten up. It also will not rotate. I've already called J&M twice with questions, and to be fair, both times they were helpful, and my assumptions about how the thing went together were completely wrong. But I just wish they'd have included a damn instruction sheet! Left a message with them today.
Lastly, got a couple of coats of chassis black on these stud plates for the strut bearings. They came with a nice bright silver coating, but I figured a little extra protection couldn't hurt, and black seemed a less distracting color than bright silver. Etch primed, and two coats of color.
Wonder bar is in.
Wonder bar is in.
