While we're all stuck at home and bored, thinking of better days, thought I could start formulating a plan.
I believe I am in need of valve seals - reason I believe this is when I am at high RPM, and let off the gas, I am burning oil as the engine winds down. Check HERE at the 0:38 mark (look at the driver's side exhaust tip). Never noticed it before the Hooker TD install - cats were probably helping to temper the appearance and smell.
Car is just a cruiser that doesn't see very much use - I've put something like 12k on it in 8 years. Car is a 2000 SS, M6, stock LS1 with performance mods limited to SLP lid, LS6 intake, Blackheart true duals, and a tune. I don't remember the exact numbers, but I believe it was roughly 350hp/350tq when Dr Phil had it on the dyno in the video. I am just shy of 80k miles on it. I am not looking to drop a ton of money, but know any project like this can become a slippery slope.
So, if I am to upgrade the valve seals, I was considering a cam. And if I am going through all that, maybe it makes sense just to throw a set of budget-friendly heads, if such a thing exists...something more favorable than the stock LS1 heads but won't break the bank. Then it got me wondering if i need to do anything with the oil pump while I am in there.
Any recommendations on what you'd do? What would you replace, what wouldn't you? Is there a option for heads that's very cost effective but will give decent enough gains?
