Rodgers - Horizontal
Results 1 to 1 of 1
Thread: How to bleed your hydraulic pump
  1. #1
    mcssmostwanted's Avatar
    Name
    Daniel Turkiela
    Vehicle
    SLO GOAT
    Join Date
    May 12th, 2006
    Location
    Find mcssmostwanted on Google Maps!Detroitish Michigan
    Age
    30
    Posts
    992
    Thanks
    141
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    How to bleed your hydraulic pump by dustin
    ***!!!Disclaimer!!!***
    The following information was gathered from various sites to provide you with some technical information. I've tried to give credit where it is due, in no way am I submitting this as my own information. Please use at your own risk and always follow basic safety precautions!!!!!
    Tools: Multi-purpose hydraulic fluid or Mineral oil, 3/16 Allen wrench
    First remove the plug with your 3/16 Allen wrench as shown in the picture below. Next fill your pump with multi-purpose hydraulic fluid that you picked up from your local auto parts store such as Auto Zone or O’Reilly’s or mineral oil you can find at most grocery stores and various other places such as Walmart, Meijer. (They carry 5 gallon buckets which is overkill for around $20 but if you can find a quart that would be perfect.) Do not over fill! Now screw the plug back in. Once you have completed this, lower and raise the top once or twice. This pumps the fluid into your lines and pushes the air into your pump. Now you can open up the pump and fill with fluid again. Continue this till you can’t fill the pump anymore with hydraulic fluid. Your top should now lower and raise with ease.
    Just some info: To lower and raise your top manually you need to turn this valve off as seen in the picture below. Turn it back on to raise it electronically.
    2005 Goat - Grass fed.
    1996 Camaro RS Vert. - Parted out and sold!
Similar Threads
  1. OBDII DTC Trouble Code List
    By 97rs4life in forum Informative Articles
    Last Post: February 6th, 2014, 09:56 PM
  2. Racetronix Plug n Play Fuel Pump Kit for 99+ LS1 F-bodies
    By Superman09 in forum For Sale (Parts and Misc. Items)
    Last Post: December 12th, 2006, 06:21 AM
  3. Meizer water pump
    By firehawknwv in forum Driveline
    Last Post: July 17th, 2006, 12:19 PM
  4. Fuel Pump on 3.8L Where?
    By phoenix_rising in forum Fourth Generation
    Last Post: April 22nd, 2006, 06:43 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
