Rodgers - Horizontal
Results 1 to 8 of 8
Thread: 4th generation v6 to v8 swap
  1. #1
    ssgtgaines's Avatar
    Name
    Andy Gaines
    Vehicle
    86 firebird
    Join Date
    August 7th, 2006
    Location
    Find ssgtgaines on Google Maps!kalamazoo
    Age
    39
    Posts
    136
    Thanks
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    :snowman: :christmastree: anyone out there have any input on swapping a v8 into a v6 4th generation camaro. has anyone done it? Would it be easier to go with a carbed 350 (cowl and hood clearancelook tight) or maybe an lt1 and pcm and wiring harness. Has any one done it or seen it done I would prefer the carbed setup. I know the suspension and some of the driveline will have to be changed. but any help or ideas would be great.
  2. #2
    SS4Matt's Avatar
    Name
    Matt
    Vehicle
    98 Camaro 5.3
    Join Date
    November 23rd, 2005
    Location
    Find SS4Matt on Google Maps!W. Bloomfield
    Age
    29
    Posts
    4,942
    Thanks
    75
    Mentioned
    8 Post(s)
    Tagged
    0 Thread(s)
    Jon "wasjo###" has a carbed 350 swapped into his once V6 bird
    Sean@CARS did an LS1 swap into a 3.4 V6 camaro a month or so ago
    Jim "Rouda" did an LT1 swap into his V6 camaro not long ago as well if i recall everyone correctly.
    the carb setup will be the worst for fitment, you have to whack out some cowel to make it work. swapping an LT1 or LS1 in a 4th gen would be the easiest since they came with them!
    you'll either need a k-member out of a V8 car, or just make new motor mounts for the V6 one. the 2 piece drive shaft from an early V6 car would not be preferable, but wouldn't be a necessity. i can't think of much more although i know there is....
    1998 Camaro SS Bullseye Turbo
  3. #3
    02redz28's Avatar
    Name
    Patrick
    Vehicle
    2002 Camaro Z28
    Join Date
    October 27th, 2005
    Location
    Find 02redz28 on Google Maps!Troy
    Age
    33
    Posts
    928
    Thanks
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Front V8 springs are stiffer to support the weight of the block...
    "ANY car can be an SS but ONLY a Camaro can be a Z28!" Scott S.
    "Owning a 9 second import is like coming out of the closet. At first you surprise everyone, but in the end you're still gay!"
  4. #4
    93formulalt1's Avatar
    Name
    Nick
    Vehicle
    1994 Formula LT1/T56-Welcome to Opti Hell
    Join Date
    December 21st, 2005
    Location
    Find 93formulalt1 on Google Maps!Belleville, MI
    Posts
    9,499
    Thanks
    61
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Yes, Dan told me that a K-member from an LT1 car would be the best bet, since it's a simple swap through the bottom of the car, and the only thing that would need to be changed in addition to that would be the wiring harness. Several people have done it, and I think it's a relatively simple operation, it just requires some time and some $$$$. Good luck!
    Nick H.
    Current MIFC Vice President
  5. #5
    SS4Matt's Avatar
    Name
    Matt
    Vehicle
    98 Camaro 5.3
    Join Date
    November 23rd, 2005
    Location
    Age
    29
    Posts
    4,942
    Thanks
    75
    Mentioned
    8 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 02redz28
    yes, but there's a hand ful of people that put V6 springs on their rears cause they're softer. again not really a necessity, hell some people like their car lowered
  6. #6
    thursday12889 Guest
    I think we need a section for engine swaps, generation specific, and motor to motor specifics. Like 4th gen LT1, LS1, & carb........3rd gen TPI, carb, covering v6 to v8 and 305 to 350 and sbc to bbc swaps, there has to be a handful of people here who have some knowledge on atleast all kinds of swaps.
  7. #7
    ZeeVert's Avatar
    Name
    Rob
    Vehicle
    2002 Camaro Z28 vert
    Join Date
    April 8th, 2005
    Location
    Find ZeeVert on Google Maps!Brighton, Michigan
    Posts
    426
    Thanks
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I already have my LS1, but I'm curious...
    ...How much would a LS1 swap cost? Used engine, trans?, K-member, wiring/ECM, etc.
  8. #8
    ROUDA's Avatar
    Name
    JIM
    Vehicle
    1995 5.7 LT-1 CAMARO
    Join Date
    February 22nd, 2006
    Location
    Find ROUDA on Google Maps!Pittsburgh,Pa
    Age
    31
    Posts
    299
    Thanks
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I did the swap took about 30hours. Did the lt1 swap cause if you want to do the ls1 swap youd be better of buying a wrecked ls1 and putting a 93-97 front end on it. You will have to rewire the whole car. Mine was plug and play except I had 2 wires put in for 4 fuel injectors. I put the v6 coil overs on my car now. I will get some good ones but Im researching and the holidays are here so Im taken it easy.
Similar Threads
  1. V6 to LT1 Swap ?'s
    By 93formulalt1 in forum Fourth Generation
    Last Post: February 16th, 2006, 07:33 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
