Hey all,
I am unsure if everyone knows what all we do, and have been getting some people mentioning they only thought we did turbo kits so I figured I would make a post to inform everyone that we in fact do much more!
Huron Speed, your local Mi-Fbody supporting vendor!
We are most known for turbo kits and components, but see below a list of everything we do. Essentially all of your aftermarket performance needs can be covered from us for of course the best pricing as well will be found from us!
TURBOCHARGING:
Turbos kits for your 98-02 F-bodies
Direct with Precision Turbo, Turbonetics, Comp Turbo, Turbosmart, Forced Inductions, BullsEye and XS-Power to provide:
-Turbo Components (turbos, wastegates, blow off valves, intercoolers, boost controllers, etc) for upgrading or DIY turbo projects
SUSPENSION/BRAKES:
Direct with BMR Fabrication, PA Racing, & CRP to provide:
-K-members, A-arms, LCAs, PHRs, Torque Arms, Relocation Brackets, Crossmembers, Shocks/Springs, Engine Mounts and much more!
-Strange Engineering & Wilwood Aftermarket Brakes
ENGINE:
Direct with Thompson Motorsports & Tick Performance to provide:
-Complete Long and Shortblocks from factory replacement to fully forged, stroker combos. Camshaft swap kits, valvesprings, pushrods, gaskets and bolt kits. CNC ported OEM and Aftermarket Casting Cylinder heads.
DRIVETRAIN:
Direct with SDPC, Circle D, & Tick Performance to provide:
-Clutches (OEM and Aftermarket), Performance Stall Converters for all applications.
REAR ENDS:
Direct with CRP to provide:
-Fabricated 9" direct bolt in rear ends, S60 rear ends, Strange Engineering Components
FUEL SYSTEM:
Direct with Fuel Injector Connection, Squash Performance, & Nasty Performance to provide:
-Fuel Injectors from factory replacement to 160#/hr Injectors for all applications. Siemens Deka, Bosch, FIC
-Dual In-tank Fuel Pump Kits for 99-02 cars
-Full aftermarket fuel line kits for upgraded Feed Line/Return Line/External Regulator/Filter/Rails/Fittings
-Complete Race Fuel Systems w/ Sumped tanks, external Fuel Pumps
TURBOCHARGING:
SUSPENSION/BRAKES:
ENGINE:
DRIVETRAIN:
REAR ENDS:
FUEL SYSTEM:
