It started with the cluster flashing (like when it starts) and the gauges dying. It happened when I was driving and if i shut down, the car would start in the Run position...by itself. Then one day, it started to miss and died. It ran intermittently and finally stopped. it fouled out the plugs, but it was not getting fuel pressure. I looked for any problems and many symptoms. I changed the ignition control module. a positive cable to my alternator and installed a fuel pump the first day it snowed in michigan. it ran for approximately 100 miles and started to miss, so i shut it off, checked the fuel pressure and it had none so i towed it home. Has anybody had a similar problem? It is an 2002 anniversary edition 3.8l. what if i wire the pump to a 12v source?
Help 2002 camaro
sounds like you have a couple things going on, not just one thing.
What kind of pump did you put in it? Did you hear the pump running when you turn the key on but no pressure?------------------------------------------
2004 GMC Envoy - Tuned, Airraid Intake, rest stock
2005 Malibu - Stock, anyone have a ecotec factory gm supercharger for me? lol
5th gen Camaro V6 Forums
http://www.bowtiev6.com
pms maybe?
i put in a 255 lph. i know it's high but i need it for the turbos. this problem is intermittent. i think the dash lights are the clue to whats wrong. whatever causing that is stopping my pump. it will start(by itself) in the on position. however i borrowed a scan tool and when the car didn't try to start itself, the fuel pump primed. i haven't messed with it for a week and i bet if i tried it would run until the cluster starts to act up. should i try to run it? i don't want to mess up that new pump. meissen suggested the vat system and i am unknowledgeable in that area. thanksLast edited by ckkhiller; January 14th, 2010, 02:03 PM.
scan tool info: car off for a week
throttle pos. 7%
eng rpm 706
eng load 3.1%
afr 5.95 Gr/sec
map 40 kpa
coolant 183*F
short term
fuel trim 1 0
long "" 1 -20.2%
short "" 2 0
long "" 2 -21.5%
short "" 3 50%
long "" 3 22.6%
short "" 4 57%
speed 0mph
ive gotten the car to run. its driven another 10 k miles. on thursday the 16th 2010, it missed and died in a down pour. i think its the computer i installed in march 2010, but i think this is caused by my original electrical problem, ignition lights flash while car is in neutral, but not it you hold the brakes. will start itself in key on pos. but not if you hold the brake pedal down.
