i have a 1500 watt HiFonics TITAN amp and two 12' SPL speakers run by 0 guage wire with a Power Acustic 10 farad cap and a pioneer head unit great setup right? WRONG!!!!!!!!!! for some reason i cant turn songs up past 15 (it goes to 40) without popping protection on my amp. i just cant figure it out. i put on Grillz by nelly and forget hearing the words i cant get past 10 and my subs shut off. what can i do?? i need some help i wanna go bump bump bump not bump..............(turn car off, start car up) bump,bump...........(repete last steps) help me please!!!!!!!!
i need help with my audio system.
Regular
- February 15th, 2006
- 76
- Danelle
- 1984 Trans am WS6,1987 Firebird Formula,1991 Camaro RS
- Casco,MI
- McDonalds
The Joke Master
- June 30th, 2005
- 8513
- Jasen
- Retiring the 80Z project and Moving on
- Grand Rapids
- Mechanical Designer
Originally posted by Orange_TerrorGet a good exhaust system, ditch the subs, then just press the gas. You'll be much happier.Western Michigan Camaro Club ~ President
1987 Camaro IROC-Z Pearl White & Black w/ Red Pearl, 355 TPI, A4, 3:42, AirRide,"GOMARO"2017 Silverado Double Cab Z71 Pepperdust Metallic, 5.3, A6, 3:42, "SASYZ71"WMCC Website www.wmcamaro.org
are willing to work and give to those who would not." — Thomas Jefferson
Or buy a small boombox and leave it in the passenger's seat. . . lolNick H.
Current MIFC Vice President
Originally posted by flandersit sounds like there may not be enough amp for the drivers or a bad ground or bad phasing for the subs to get the resistance down
GROUND is the problem. I almost guarantee it. Check the connection to ground for the amplifier and make sure it is attached to bare chassis metal. I made this mistake once and the same thing happened to me, it took me 2 days to figure it out.sigpicAnd another thing.....when I gun the motor, I want the whole world to think it's coming to an end.
-Homer Simpson
yeah i would say either the ground....or the amp isn't enough to power the SPL subs...a friend of mine had that problem...the speakers would rip so much juice through the amp that it would go into "safe/protect" mode and same thing...i am willing to bet that the amp just isn't enough1998 Camaro SS Bullseye Turbo
I've ran into this problem many times with subs. Ususally it was the speaker wire. If you have pieces connected, make sure they have lots of electrical tape but make it so the wire comes from the amp and to the box as one wire, not pieces twisted together, same with speaker wire coming from the box to the subs. Ground is sometimes the problem but not usually. On my car I just took out the carpet in the back and unscrewed something and grounded it there, but make sure you sand the paint off in that area, it improves it alot.
Regular
- 76
- Danelle
- Casco,MI
- McDonalds
ok i have zero guage wire nothing is crossed but i will check the ground right now i have the setup in a 2000 sunfire and i hooked the ground up by the rear seat release do you think that could be it and if so where would be a good place. i did pop one fuse but that was because of a car problem that is the only time i popped a fuse other than that it has just been popping protection.
