EuroLamps - Horizontal
Results 1 to 4 of 4
Thread: How to unlock a THEFTLOCK or DELCO-LOC II audio system
  1. #1
    white96TA's Avatar
    Name
    John
    Vehicle
    2011 Synergy Camaro RS , 1996 T/A vert
    Join Date
    March 10th, 2008
    Location
    Find white96TA on Google Maps!Michigan
    Posts
    3,029
    Thanks
    213
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This is how to unlock a THEFTLOCK or DELCO-LOC II audio system
    DELCO-LOC II
    Disabling the anti-theft feature
    1.) press the sterio's PREV and FWD buttons at the same time for five seconds with the ignition on and the radio power off. The display will show SEC, indicating the unit is in the secure mode (anti-theft feature enabled)
    2.) Press the set button. The display will show "000"
    3.) Press the SEEK button to make the first number appear.
    4.) Rotate the TUNE knob right or left until the second and third digit of your code appear. The numbers will be displayed as entered.
    5.) Press the band knob. "000" will be displayed
    6.) Press the SEEK button to make the fourth number appear.
    7.) Rotate the lower knob until the fifth and sixth digits of the code are displayed.
    8.) Press the lower BAND knob. If the display shows "_ _," you have sucessfully disabled the anti-theft feature. If SEC is displayed the code you entered was incorrect and the anti-theft feature is still enabled.
    Unlocking DELCO-LOC II after a power loss
    when power is restored to the stereo, the stereo won't turn on and LOC will appear on the display. Enter your ID code as follows;
    1.) Turn the ignition switch to ON, but leave the stereo off.
    8.) Press the lower BAND knob. If the display shows SEC appears, the numbers you entered were correct and the stereo will work. If LOC is displayed the code you entered was incorrect and the stereo will be inoperative.
    THEFTLOCK
    1.) Press the stereo's 1 and 4 buttons at the same time for five seconds with the ignition on and the radio power off. The display will show SEC, indicating the unit is in secure mode (anti-theft feature is still enabled)
    2.) Press the MIN button. the display will show "000."
    3.) Press the MIN button to make the last two numbers appear.
    4.) Press HR to display the first one or two numbers of you code. The numbers will be displayed as entered.
    5.) Press AM/FM. The display shows "_ _," you have successfully disabled the anti-theft feature. If SEC is displayed, the code you entered was incorrect and the anti-theft feature is still enabled.
    Unlocking the stereo after a power loss
    3.) Press the HR button to make the last two numbers appear.
    4.) Press the HR button until the first one or two numbers appear
    5.) Press AM/FM. SEC shoulld appear, indicating the stereo is unlocked. If LOC appears, the numbers you have entered were not clorrect and the stereo is still inoperative.
    HOPE THIS HELPS!!!
    should sticky this
  2. #2
    TSTONE's Avatar
    Name
    TSTONE
    Vehicle
    1968 Camaro Convertible & 1977 (Y82) Trans Am SE
    Join Date
    September 20th, 2006
    Location
    Find TSTONE on Google Maps!CLARKSTON
    Age
    49
    Posts
    11,591
    Thanks
    181
    Mentioned
    30 Post(s)
    Tagged
    0 Thread(s)
    good write up -thanx
    phoenix_rising Guest
    Good write up. BTW If you do not know your ID code (Different for each stereo unit) you can get it from any GM dealership.
  4. #4
    92conv's Avatar
    Name
    Scott V.T.
    Vehicle
    Too many!! :)
    Join Date
    February 22nd, 2008
    Location
    Find 92conv on Google Maps!Holland, Mi
    Age
    45
    Posts
    9,331
    Thanks
    1,535
    Mentioned
    99 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by phoenix_rising View Post
    You may have to check with a few dealerships before getting one to just give you your code. Most of them would rather charge you $$ to unlock it.
    Locally I think they get $75 a pop to unlock your radio. Crazy when you see how little is involved in doing so.
    West Michigan Pontiac Club
Similar Threads
  1. OBDII DTC Trouble Code List
    By 97rs4life in forum Informative Articles
    Last Post: February 6th, 2014, 10:56 PM
  2. [FQuick] GM Announces 2nd-generation Hybrid System
    By Mini-Meissen in forum Automotive News and Announcements
    Last Post: March 4th, 2008, 12:20 PM
  3. audio system help
    By Xavierz28 in forum Audio Video
    Last Post: February 1st, 2007, 06:15 AM
  4. audio system...cheap...free shipping...
    By erk2581 in forum For Sale (Parts and Misc. Items)
    Last Post: December 13th, 2006, 06:43 PM
  5. i need help with my audio system.
    By Brink_2000 in forum Audio Video
    Last Post: June 29th, 2006, 08:38 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
