L&L Arms - Horizontal
Results 1 to 5 of 5
Thread: how to remove EGR on lt1
  1. #1
    Name
    Matt
    Vehicle
    07 Jeep Liberty...:(
    Join Date
    July 24th, 2007
    Location
    Find goblue9976 on Google Maps!Farmington Hills, MI
    Posts
    121
    Thanks
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exclamation how to remove EGR on lt1
    As the title says, How do you remove the EGR valve on a 95 LT1. I got the vacuum hose off of the passenger side of it, but cant figure out how to finish the job. ANy help would be appreciated.
    http://www.youtube.com/watch?v=b8-pCbQnSC4
    "Wow Pete, I have to say your balls are so tender."
    "Well theres no beating my balls, the are made from a secret Schweddy recepie."
  2. #2
    JoeliusZ28's Avatar
    Name
    Joel
    Vehicle
    1995 Z28
    Join Date
    April 18th, 2005
    Location
    Find JoeliusZ28 on Google Maps!sideways and smiling
    Posts
    29,471
    Thanks
    4,551
    Mentioned
    125 Post(s)
    Tagged
    1 Thread(s)
    depends if you want to block it off, or actually remove everything. this thread should have some good information for you:
    http://www.camaroz28.com/forums/show...ht=egr+removal
  3. #3
    Name
    Matt
    Vehicle
    Join Date
    July 24th, 2007
    Location
    Posts
    121
    Thanks
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    well actually i ment replace, but I figured it out anyway. thanks for the links!
  4. #4
    TSTONE's Avatar
    Name
    TSTONE
    Vehicle
    1968 Camaro Convertible & 1977 (Y82) Trans Am SE
    Join Date
    September 20th, 2006
    Location
    Find TSTONE on Google Maps!CLARKSTON
    Age
    49
    Posts
    11,591
    Thanks
    181
    Mentioned
    30 Post(s)
    Tagged
    0 Thread(s)
    1993-97 5.7L ENGINE
    See Figure 10
    1. Disconnect the negative battery cable.
    2. Disconnect the vacuum line from the EGR valve.
    3. Unfasten the retaining nuts, then remove the EGR valve from the vehicle. Remove and discard the gasket.
    4. Clean the EGR valve gasket mating surfaces.
    Fig. 10: Negative backpressure EGR valve mounting-1993-97 5.7L engine
    To install:
    1. Position a new gasket, then install the EGR valve on top of the gasket.
    2. Install the retaining bolts and tighten to 16 ft. lbs. (22 Nm).
    3. Attach the vacuum hose to the EGR valve.
    4. Connect the negative battery cable.
    96BlackBetty's Avatar
    Name
    Shawn A. Williams
    Vehicle
    1996 Pontiac Trans Am and 1994 Pontiac Firebird
    Join Date
    May 31st, 2007
    Location
    Find 96BlackBetty on Google Maps!Ortonville Michigan
    Age
    28
    Posts
    1,584
    Thanks
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Do u really gain anything fron taking this off?
    Im Gonna Party Like A Rock Star, Hit A Bunch Of Strip Bars, Wake Up Naked In A Hotel Room, Through My TV Out The Window, Smoke A Bunch Endo Cause Tonight Im Wanted Dead Or Alive
Similar Threads
  1. Stereo Install on 2002 Trans Am Convertible (w/Monsoon) by wyo_vr4
    By mcssmostwanted in forum Convertible Tech
    Last Post: January 10th, 2015, 11:03 AM
  2. Did rear rotors and pads today but....
    By apyah in forum Fourth Generation
    Last Post: January 6th, 2008, 03:23 AM
  3. How do you remove the TB shaft?
    By OIF1VET in forum Intake / Exhaust
    Last Post: January 14th, 2007, 07:32 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
